Page 1 of 1
Remove/install rear vision mirror covers
Posted: Wed Aug 18, 2010 7:50 pm
by WTR
Did a search and couldn't find anything - anyone have info (preferably with pics ) ?
Posted: Wed Aug 18, 2010 7:53 pm
by LZY_EYE
If I get a chance tomorrow I will have a look at my spares.
Posted: Wed Aug 18, 2010 7:55 pm
by WTR
Thanks, Shane.
Posted: Wed Aug 18, 2010 8:03 pm
by LZY_EYE
I have a feeling that you need to just pop the covers off.... I haven't done it though!!!!
Posted: Wed Aug 18, 2010 8:07 pm
by WTR
I agree - the new ones have plastic "fingers" with "L" shaped hooks. I assume the originals are the same. But if not removed correctly, could end in tears !!
Posted: Wed Aug 18, 2010 8:08 pm
by LZY_EYE
I know where there are some spares... just need painting
Can do them in evo black for you
Posted: Wed Aug 18, 2010 8:15 pm
by WTR
Not needed, Shane - I've bought a set from ofey with the LED indicators. Just need to get them painted. Thanks for the offer though....
Posted: Wed Aug 18, 2010 8:22 pm
by LZY_EYE
I know... was just a joke
Depends on what time I get home tomorrow... I hate it being dark when I get home
Posted: Thu Aug 19, 2010 9:10 pm
by WTR
Hey Shane - worked it out !!
Removing - start at the lower edge nearest the door.... grip cover ( fingernails help ) and pull down. Corner should come away from mirror housing. Work your way outwards from the door, along bottom edge. Then lift cover (gently !! ) upwards. Voila !!! Cover removed.
Replacing - line up the 3 "fingers" along the lower edge of the cover with the slots in the mirror housing. Press the cover inwards until the cover engages fully on the housing.
Happy ...happy !!!
Posted: Thu Aug 19, 2010 9:42 pm
by WTR
G'day Ryan ... new covers not fitted yet - still need to be painted. I don't think it will be hard to wire - piggy back off the side indicators on the front guards.
Posted: Thu Aug 19, 2010 9:44 pm
by ofey
WTR: Have you considered just looking at the wiring that's used by those who have the folding mirror thing? There are some wires we tap from the fuse box on the pax side behind the fuse box, just use those quick connectors to tap onto the same signal lines.
If you need the instruction manual in PDF, PM me your email address.
Posted: Thu Aug 19, 2010 9:50 pm
by WTR
G'day ofey ...... I haven't looked into it in depth - just thought it wouldn't be that hard to get 2 wires down to the existing side indicators and tap off them.
Posted: Fri Aug 20, 2010 8:28 am
by aspir3
No definately easier joining them under the dash.
Posted: Fri Aug 20, 2010 10:24 am
by ofey
Far neater solution though. To connect to the side signal indicators, there is no rubber hosing to carry it across from the door and secondly, when you open your door, you'll have this wire hanging across.
I still think quick connectors onto the fuse box as per the folding mirrors is a far more elegant solution.
