Hi
Just got some led taillights from mars performance. Fitted ok but now traction control warning coming on 2 days after fitting. Says service required. Seems the leds has caused this. What can i do to fix?
Cheers
Led causing issues
Hey Keith .....
read/view Ofeys second post Posted: 28th Jul 2009, 11:03pm:LED Tailights - Load Resistors
It shows the 5watt 180 Ohm Resistors you need to use & where/how to fit them.
These will remedy/fix your problem.
JayCar 5watt / 180 Ohm Wire Wound Ceramic Resistor
Catalog Part No: RR3280 ........ 40 cents each.
Sam .....
Merlinised AspiRe 2.4L
Sam .....
Sam .....
No .... I don't believe so .... it's happened to many of us before with no probs.
The worst it can do is disable your ASC Active Stability Control and/or Cruise Control.
So be mindful of these disabled features and drive accordingly/safely until the resistors are fitted.
Sam .....
Users browsing this forum: No registered users and 54 guests
