Side license plate mount, legal?
Neo
Postby Neo » Fri May 18, 2012 12:28 am
i was going to use some double sided tape and just put my license plate on the side but im wondering whether its legal or not? :?
thanks :D
E-dawg
Postby E-dawg » Fri May 18, 2012 1:18 am
The exact rule would vary by state, but I see plenty of Lancer Evos and supercars going around with side licence plates mounted. So it would be legal, it's just how angled, positioned, visible, etc. :)
Work Hard, Play Hard, Drive Hard.
zedd82
Postby zedd82 » Fri May 18, 2012 8:15 am
I think in QLD it has to viewable from an angle of 45 degrees on either side at a distance of 25m. I asume most other states would probably be similar.
eshanes
Postby eshanes » Mon May 21, 2012 1:50 pm
I believe it's the same requirements in NSW, .
In saying that, I have my number plate cable tied to my grill and I've never come into any strife.
Best off checking with MainRoads or their equivalent just to make sure.
Fitter
Club Vendor
Club Vendor
Postby Fitter » Mon May 21, 2012 2:32 pm
Needs to be secure. Double sided tape wouldn't be accepted as the plate can easily come off. Zipties or bolts :)
CLUB CJ CAR AUDIO VENDOR
2013 WORLD TITLE
2012 QLD State Champion
2008 Australian Champion
MRWOLF
Postby MRWOLF » Mon May 21, 2012 4:00 pm
Aspir3 (Troy) down in SA has his Velcroed and from what I read it has never come off...
Whether or not using tape is strong enough or legal I'm not too sure
You can buy the side mount plate from body kingdom in QLD or on eBay however, the measurements for one hole Is bout 2cms off... Just simply drill a new hole and it's all fixed
Tadz0rz and 13EZY have side mounted the number plate have a look at their garage
Mine's quicker then yours!!!
Range Rover Sport 2014-
2013 WRX: 2013-
2009 Lancer: 2010-2013
2003 Astra: 2008-2010
LZY_EYE
Postby LZY_EYE » Mon May 21, 2012 5:20 pm
If a cop wants to be picky they can argue that the plate is not in the stock position etc.
A side mount plate is illegal due to not being able to see the plate at 45deg like has been said already.
The pitch on the lancer bar means that you have to have a pretty large mount to meet the requirements.
It is one of those things, if you treat people with respect you may get away with it, but it is not legal.
AllBlue
Postby AllBlue » Mon May 21, 2012 8:29 pm
My plates are on the side and have not been pulled over yet by any police.
if i pass any police they just look and do nothing else.
WTR
Postby WTR » Mon May 21, 2012 9:10 pm
And it looks ghey .....
brent0013
Postby brent0013 » Mon May 21, 2012 9:14 pm
i was asked by the dealership if i wanted it in the middle or off to the side when i bought mine. cause they didnt have a place to screw it in to the aftermarket bumper
13EZY
Postby 13EZY » Mon May 21, 2012 9:16 pm
I got pulled over by the cops and politely asked to increase the angle which I did. no dramas since :)
its perfectly legal as long as the requirements mentioned by Zedd82 are met.
as Lazy eye mentioned the front bar has a fair slope which makes a side mount stand out a fair bit too
Ride Of The Month June 2011
Joel006
Postby Joel006 » Sat May 26, 2012 10:09 am
Yeah as stated above QLD legislation says:
Veiwable from 45 degrees from center of the plate and veiable from either side of the car. So if you get the proper mount for it which brings the plate flush with the front just a bit offset im going to say that would be legal.
as for taping it to the bumper with a slight bend in it. No i don't believe this would be legal.
Car: 2012 Mitsubishi Lancer Platinum Edition
Colour: White
Mods: (Nothing Really) K&N Air Filter, Dark Black Window Tint, White LED Strip behind Front grill
Upcoming Mods: Evo like Front Bumper
LZY_EYE
Postby LZY_EYE » Mon May 28, 2012 9:35 pm
And the Alfas if you look closely even though it is side mounted, it is almost straight, and not at an angle...
Users browsing this forum: Google [Bot] and 22 guests
