thanks
Side license plate mount, legal?
i was going to use some double sided tape and just put my license plate on the side but im wondering whether its legal or not?
thanks
thanks
Aspir3 (Troy) down in SA has his Velcroed and from what I read it has never come off...
Whether or not using tape is strong enough or legal I'm not too sure
You can buy the side mount plate from body kingdom in QLD or on eBay however, the measurements for one hole Is bout 2cms off... Just simply drill a new hole and it's all fixed
Tadz0rz and 13EZY have side mounted the number plate have a look at their garage
Mine's quicker then yours!!!
Range Rover Sport 2014-
2013 WRX: 2013-
2009 Lancer: 2010-2013
2003 Astra: 2008-2010
2013 WRX: 2013-
If a cop wants to be picky they can argue that the plate is not in the stock position etc.
A side mount plate is illegal due to not being able to see the plate at 45deg like has been said already.
The pitch on the lancer bar means that you have to have a pretty large mount to meet the requirements.
It is one of those things, if you treat people with respect you may get away with it, but it is not legal.
I got pulled over by the cops and politely asked to increase the angle which I did. no dramas since
its perfectly legal as long as the requirements mentioned by Zedd82 are met.
as Lazy eye mentioned the front bar has a fair slope which makes a side mount stand out a fair bit too
Ride Of The Month June 2011
Yeah as stated above QLD legislation says:
Veiwable from 45 degrees from center of the plate and veiable from either side of the car. So if you get the proper mount for it which brings the plate flush with the front just a bit offset im going to say that would be legal.
as for taping it to the bumper with a slight bend in it. No i don't believe this would be legal.
Car: 2012 Mitsubishi Lancer Platinum Edition
Colour: White
Mods: (Nothing Really) K&N Air Filter, Dark Black Window Tint, White LED Strip behind Front grill
Upcoming Mods: Evo like Front Bumper
Colour: White
Users browsing this forum: No registered users and 50 guests
