Side-mount/offset licence plates
vincentchua
Postby vincentchua » Sat May 08, 2010 9:33 pm
Is it legal in Qld? Can it be mounted easily using some of the stock kits available on the 'net?
2008 Lancer Ralliart
Pipewerx Custom catback exhaust
Racing Dynamics 18x8" wheels
Chiptorque custom tune
----- Rice Rice baby! -----
vincentchua
Postby vincentchua » Sat May 08, 2010 9:35 pm
this is on an RA by the way...
tadz0rz
Postby tadz0rz » Sat May 08, 2010 9:38 pm
Depending on state regulations, i believe the licence plate must be fully visible from a 70 degree angle. Im sure only a real hard ass will know this and try to pull you up for it...
Ral1rt has a side mount on his RA and as far as i know he hasnt had any trouble with the fuzz
SIR-VRX
Postby SIR-VRX » Sat May 08, 2010 9:38 pm
Technically illegal...
But easy to do yes, various methods and mounts out there.
Blakey
Postby Blakey » Sat May 08, 2010 9:40 pm
it has to be parallel to the front axle. in QLD so it would be illegal.
billyboy
Postby billyboy » Sat May 08, 2010 10:10 pm
Was looking into this myself, was thinking of doing the evo x nose mod a while back...
Found this link relating to NSW: http://www.legislation.nsw.gov.au/fragv ... 2-pt.5+0+Y
Looks like its the same for QLD: http://www.transport.qld.gov.au/Home/Re ... er_plates/
Think its the luck of the draw if you'll get defected, depending on the popo pulling you up. :?
JaCe
Postby JaCe » Sun May 09, 2010 12:40 am
I also looked into this at one stage and calculated it would cost me somewhere around $450-500 all up including installation, CF front (to replace the holes where the current plate are) and the correct mounting plate below the HID washers on my car. In summary, too expensive for too little.
Blakey
Postby Blakey » Sun May 09, 2010 8:58 am
JaCe wrote:I also looked into this at one stage and calculated it would cost me somewhere around $450-500 all up including installation, CF front (to replace the holes where the current plate are) and the correct mounting plate below the HID washers on my car. In summary, too expensive for too little.
450 is nothing to alter rego plates, my plates alone cost me $2200.
Also on what billyboy said there is another regulation somewhere that tells you the actual placement of numberplates, how they should be attached, they can be attached and where they cant be attached,
from memory of reading this regulation, it can be mounted anywhere on the front or rear as long as the plate is parallel with the associated axle, and viewable from 45degrees of the car at 20m.
JaCe
Postby JaCe » Sun May 09, 2010 9:21 am
You spent $2200 on relocating your plates??!!!
Blakey
Postby Blakey » Sun May 09, 2010 9:22 am
no just for the plates lol they are in kinda stock position.
Image[/img]
JaCe
Postby JaCe » Sun May 09, 2010 9:25 am
Pshh that's to be expected- they're personalised plates!
But $450 just to relocate them from front to side with no real benefit... I thought I'd rather put that money towards other things.
Blakey
Postby Blakey » Sun May 09, 2010 9:28 am
yer i guess but you wouldn't need to buy the CF nose piece you can just get a FG one.
Postby aspir3 » Sun May 09, 2010 10:46 am
If you have the black vinyl front I would get small Black personal plates and fit them centrally between the grills.
I hold my plates on with velcro strips. Easy for cleaning.
There are also some number plate frames that help locate it centrally. Aspired has a nice one.Image URL: http://www.images.clubcj.net/results/20 ... spired.jpg
BBCode: Image
bobcrusader
Postby bobcrusader » Sun May 09, 2010 11:32 am
I bought a plastic holder off eBay, but it is designed for the smaller US style plates. My vic plates are 2 inches too long. Still haven't figured out a way to fix the problem, so the plate is held on by two zip ties to the lower grill.
- 2009 Lancer Ralliart
- Boostpill + Tune
- Upgraded intercooler + pipes
- Turbo XS Catback
- Drift BoV
- Blitz Air Filter
billyboy
Postby billyboy » Sun May 09, 2010 4:59 pm
^ Cant you still centrally mount your plate onto the holder Bob, 1 inch over hang either side wont look too bad will it?
This is the UK spec side holder, though I think this will be bit too long for our plate specs. Cant win either way...
aspir3 wrote:I hold my plates on with velcro strips. Easy for cleaning.
Aren't you concerned that this will make it simple for someone to steal your plates? :shock: Dunno about SA, but happens quite a bit in NSW.
Users browsing this forum: No registered users and 103 guests
