Front Grille Vinyl // Number plate question
- Blackjack
Hey all,
I see a lot of you have the matte black vinyl for the front centre bit.
Im also getting this done on the weekend but im wondering, where am i going to put my number plate!
Not sure if i want to put it on the corner, i like how Tadz0rz is on the bottom part of the grille, how can i get it to stay on like that?
Mate I have the NSW slimline plates and I have mine in the lower grill to the right hand side of the car (I will try and fine a pic for you). I have got mine held on with two cable ties and there is no way that plate is going anywhere
here is one will try and find a better one;
3rd from the top on the right most column.
yeah mine is wrapped around under the grill, I infact took the grill out for the signwriter as I did not want them doing.
The only thing I have found with mine is it has some small tears where the number plates holes are in the bumper, I should have glued something into them or taped over them first. However the only reason it did tear was from a higher speed.
If done properly it is imposible to tell if it is painted or not.
If you paint it and stone chip it then it will look shite house untill you repaint it!
If the vinyl gets damaged then just remove and replace.
I will take a closeup pic of mine shortly and see if you can tell the difference.
Official ClubCJ Sponsor.
