Anyone seen snyo of these their their adventures
http://imgur.com/a/1xjXzNY
I'm chasing some of these
If you look at the rear door on the sedan there is a small vertical piece of rubber about 40cm long
When you open the rear door the rubber is on the door that is now open and close to the upper front of the rear door close to the front door
Hope that makes sense
It will when you open the rear door and look
Cheers
rear door clip's?
rear door clip's?
Re: rear door clip's?
You should be able to pick them up from a spare parts store. They look the same as most Japanese car trim clips
Cheers mate
I will do some more investigation and see what I come up with
