Gday guys
I learnt something new today while getting my fusion amp replacement done to an alpine.
The door speakers i have are the jaycar 6.5 inch kevlar responce speakers rated at 75WRMS and 4 ohm
So if we do 75 times 4 we get 300
Do a square root of 300 and we get 17.3volts
So with the speakers disconnect from the amp.the header unit to flat response and it playing a test tone of 1Khz at 0dB and with the header unit volume set to full bore .set gain on amp to zero.put an AC multimter across the speaker out put and slowly wind up the gain on the amp till you hit 17volts.
Done.
Wind the volume down on the header unit and remove the test tone and power it.all off and plug the speaker leads in the header unit and power it up again
Enjoy your stereo in all its awesomeness and you wont turn your speakers to a molten pool of mess
setup stereo header unit to amp correctly
- Lancer Learner
Re: setup stereo header unit to amp correctly
Top notch! Thanks for that, I always wanted to know how they tuned their speakers to eliminate clipping.
RA intake, TOG air filter, pedders street suspension, Twm full cage short shifter, RRM lightened crank pulley, 67mm throttle body, supercircuit 4-2-1, rapid straight through sports exhaust, ultraracing parts, T2 slotted rotors all round. Most importantly Merlinised. And stuff.....yeah she's not stock anymore.
Anytime
Glad you found it handy
Users browsing this forum: No registered users and 64 guests
