Vinyl Wrap
Luke
Vinyl Wrap
Postby Luke » Wed Dec 04, 2013 10:19 pm
Hi all, two quick questions;
I'm looking to do some wrapping on the interior silver ES trim, and just was wondering;
1. Where's the best place/website to buy vinyl wrap?
2. Should I DIY or get professionally done?
shadow-vex
Postby shadow-vex » Thu Dec 05, 2013 7:14 am
1) ebay
2) how patient are you and how good are u at wrapping books with contact, coz if u are neither of them I'd say get it done professionally
Luke
Postby Luke » Thu Dec 05, 2013 7:26 am
shadow-vex wrote:1) ebay 2) how patient are you and how good are u at wrapping books with contact, coz if u are neither of them Id say get it done professionally
Is there anything specifically I should search for? Or just #colour# vinyl wrap?
And I'm usually okay with schoolbooks :D
shadow-vex
Postby shadow-vex » Thu Dec 05, 2013 7:40 am
Yeah u can search that or if u want the good quality stuff add "3m" (the company, not 3 metres) into your search
RallyNut
Postby RallyNut » Thu Dec 05, 2013 7:55 am
I tried to wrap my bonnet on monday. didnt turn out so well, had to abandon the idea.
wrap it self is quite cheap20 bux gets you a decent size sheet. but if your going to get some one to do it for you, the cheapest i found to wrap my bonnet was $250...
there are some little trick to it if your gona do it your self, but still takes lots of time.
Luke
Postby Luke » Thu Dec 05, 2013 9:37 am
RallyNut wrote:I tried to wrap my bonnet on monday. didnt turn out so well, had to abandon the idea. wrap it self is quite cheap20 bux gets you a decent size sheet. but if your going to get some one to do it for you, the cheapest i found to wrap my bonnet was $250... there are some little trick to it if your gona do it your self, but still takes lots of time.
Probably should be alright because it's only interior.
Luke
shadow-vex wrote:Yeah u can search that or if u want the good quality stuff add 3m (the company, not 3 metres) into your search
Cheers man :)
Damir
Postby Damir » Thu Dec 05, 2013 2:28 pm
wrapping is very easy actually, a bonnet is simple minus the water sprays because it is a flat surface
the secret to wrapping is use high end wrap and its a breeze
brands like avery, 3M, and hexis are the way to go
take out the silver stuff (very easy), apply the vinyl and then heat it up
after its flush, then cut out the access and place everything back
for you first time it should take about 1-2 hours
Return to “Interior”
