Removing silver plastic door trims?
Re: Removing silver plastic door trims?
Postby bumblebee » Mon Sep 11, 2017 10:34 am
Sound deadener the door AND upgrade the speakers at the same time ;-)
Don't forget to grab some speaker adaptors so you can use aftermarket jobbies
Online
Postby Lancer1993 » Mon Sep 11, 2017 5:34 pm
I've used yellow Plasti-Dip on my CJ for almost 2 years with no noticeable loss in color.
Online
Postby Lancer1993 » Mon Sep 11, 2017 9:20 pm
bumblebee wrote:Sound deadener the door AND upgrade the speakers at the same time ;-)
If only I could afford it :(
Reality is taking the door cards off (yes card is the correct term) is no big deal. Did it a number of times on the CC coupe, even swapped them from a M21 went I did a power window upgrade so I'm no stranger to this. I'm just careful doing it on a newer car until I know exactly how to do it, but seen a few YT clips and its pretty easy but the look!
Return to “Interior”
