Hi guys, thinking of upgrading to the evo intercooler set up. Can't seem to find any currently for sale. Would prefer NSW
Only thing i've found are aftermarket units -
http://www.gumtree.com.au/s-ad/coopers- ... 1073300263
is this a viable option if all else fails ?
WTB : Evo X intercooler with piping
- rustybucket
I have been wondering about that exact set.
Anyone with any experience with these?
Also available on ebay
http://www.ebay.com.au/itm/KLS-turbo-In ... 541c26f0a6
i have 1 stock Evo X cooler left with stock pipes.
as for china IC, NOT saying the above is the case. but we did alot of testing on a few and found they performed less that stock evo X once heat soaked. where as high end coolers like ultimate racing, plazaman, ETS, AMS etc work better. in both temps and pressure drop.
I've had great results from the cheaper Chinese (KLS) coolers for anything under about 250 kw. Above about 27-28psi yes they do tend to perform worse than the more expensive brands. But for a street car with, say 220wkw, they perform flawlessly with minimal heat soak. If you are tracking hard, I would lean towards something like a Plazmaman cooler, but if you are not beating on it hard it will make a minimal difference.
230kw/430nm @ 24psi on E85
12.191 @ 108.81mph - Fastest stock turbo ralliart in Australia
www.facebook.com/BoostinJuiceTuningSydney
www.clubcj.net/viewtopic.php?p=369141#369141
