WTB: Double Din Facia
Post Things You Are Wanting To Buy Or Trade.
R4LLI4RT
Postby R4LLI4RT » Thu Feb 05, 2015 3:31 pm
Hi Team,
need a double din for my awesome $200 chinese dvd player.
if any1 has one with a reasonable fit please me know
victoria prefered.
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
Postby Lancer1993 » Thu Feb 05, 2015 8:26 pm
Love that one of the pics used is of a HU with a tape deck... was the CJ ever offered with a tape deck?
Also for a different look I'd consider getting some vinyl paint or there is a method now that can make them look like carbon fiber, depending on the look you're going for. It's called hydro dipping, ask around at paint shops it's a cool way to customize small body parts like that.
bunnishiwa
Postby bunnishiwa » Fri Feb 06, 2015 7:44 am
http://www.ebay.com.au/itm/CAR-RADIO-ST ... 4d155d8138
This is who I brought mine off. Had for 4 years - does exactly what it should and looks fine. Not quite a 100% fit but, as stated above, hardly noticable
- Lowered on Kings
- Whiteline Rear Swaybar
Noli Timere Messorem
mcpondy
Postby mcpondy » Fri Feb 06, 2015 8:04 am
I bought this just the other day:
http://www.ebay.com.au/itm/261193181272
I havent fitted it yet, but the finish seems ok, no scratches etc. Looks good so far, but I'll see when its fitted. It also turned up the next day after ordering :-)
Postby Lancer1993 » Fri Feb 06, 2015 8:23 am
Do we have a DIY here for fitting them?
mcpondy
Postby mcpondy » Fri Feb 06, 2015 8:40 am
Theres a DIY for removing it. If you can remove one, you can fit one quite easily :-) I might put some pics up as I do mine though, hoping all the parts arrive to fit next weekend.
Postby Lancer1993 » Fri Feb 06, 2015 9:05 am
I'll look, just wondering how much space is behind the strip that runs the width of the dash with the hazard switch in it. I have a dash cam and GPS power I'd like to hide.
r00tc4u53
Postby r00tc4u53 » Fri Feb 06, 2015 9:30 am
Lancer1993 wrote:Ill look, just wondering how much space is behind the strip that runs the width of the dash with the hazard switch in it. I have a dash cam and GPS power Id like to hide.
Just run the lead across the header rail of the hoodlining, down the A pillar trim, under the rubber door seal, under the carpet on passenger side and up under\behind dash and what not, video of it on youtube dashcam owners australia channel, takes about 30mins.
Return to “Buying & Trading”
