2008 Lancer CJ VRX - Build thread
Avenir
Re: 2008 Lancer CJ VRX - Build thread
Postby Avenir » Tue Apr 06, 2021 9:19 pm
BUILD UPDATE:
She's done boys. Over the long weekend the lancer got the last of its parts before getting back onto the road. Dad and I hoisted it up, removed the entire back end of the car (in total 4 different arms each side that link the suspension together.) and tallied up the bushing count.
After some analysis we realised I was short 4 bushings (which was bound to happen, we went off of a warehouse trader page with no diagrams), but we found a home for all of the 10 bushings I did get. In short, the lancer back end suspension consists of: 1 large trailing arm that goes down to the hub, 1 upper arm (banana arm we called it), 1 small lateral arm that connects to the centre of the back end, and 1 larger lateral arm at the very back each side that hold the edge of the trailing arm, coilover and connects to the upper frame of the car.
Might sound confusing at first, but taking it all a part it really makes a lot more sense, and isn't very complex. Each arm had 2 bushes each, excluding the trailing as it only had 1 BIG bush at the top of it. So (1 + 2 + 2 + 2) * 2 is 14 bushings all up. The only ones I didn't change because I didn't have, are the longer back end lateral arm bushings. Spose they would be called lower outer and lower inner bushes, but they weren't worn much anyways.
Anyway, we did 1 half of the back at a time so we could rebuild each side with a reference... Disassembled, took all 3 arms to work, used the hydraulic press countless times and meticulously pushed each out with various bearings, cylindrical pieces of metal and anything else we could find. We ran into some shit half way through, actually a couple times. Putting the wrong size bushing into a bigger arm, (which we released it was for the tiny lateral instead) and mushrooming an old trailing arm bush ahaha. Eventually all got out, all the new polys in, took them back rebuilt 1 side and rinse and repeat with the other side.
Initially we were not going to do the big trailing arm bush as you have to take the brake lines apart, the hand brake line, caliper off, rotor off, hub off, etc. Just to bloody see what your doing. It was a lot of work for one bush, I now know how the inner workings of all my brakes etc work. Quite simple as well! Oh also we actually improved the handbrake action a LOT by disassembling it, my handbrake has VERY satisfying clicks and stages that you can feel, also goes further easier too.
Once putting it all back together and rotors/calipers back on, we then had to bleed the brake lines of air, and boy did we do that for a while. Probably an hour just doing all 4. Eventually I felt a bit of a placebo with the brakes, we stopped and they ended up being extremely responsive as we got virtually all the air possible and entirely new brake fluid by the end of it.
After that we did a cheeky oil change because why not, with a NEW OIL FILTER this time, last time we had to reuse my old one, cleaned up because I got given the wrong one... Topped off with the wheels aligned this morning, the car is GOLDEN.
It's scary how fast I can go round a roundabout or corner now, it just keeps hold of the road so much differently then it use too, and no more lifting. The car rides hard, it's not uncomfortable though. The only thing I found uncomfortable at times, is the BIG dips and ditches, because when I hit them now the suspension just drops instantly, and comes back up instantly, so it throws your head around. But medium to small sized dips etc are quite placid.
Also forgot how quick this car is then the Getz I was driving, holy balls and its not even tuned yet.
Got some very busy weekends up ahead that are not car related, so hoping I can still fit in a time to get the rest of bits and pieces sorted for it, that I have talked about in the past. Few pics below of some bushes and the front control arms with poly's from a build update ago.
What do you guys wanna see next? I haven't got many parts to go now.
Avenir
Do not go gentle into that good night. Rage against the dying of the light.
2008 Lancer VRX Manual
K&N Typhoon Intake + RA Snorkel
4-2-1 OBX Heat Wrapped Extractors
TS Short Shifter
2.5 Magnaflow Cat Back
XYZ SS Coilovers + SuperPro Perf Control Arms
Mars1811
Postby Mars1811 » Wed Apr 07, 2021 2:13 am
Good work Avenir! Good to hear it all went well.
Love reading through the build logs!
M
2011 VRX Sportback
If in doubt, rev it out!
Viking
Postby Viking » Wed Apr 07, 2021 5:52 pm
Nice work. As Mars said, it's good to hear everything went (mostly) smoothly and you're back on the road again.
Postby bumblebee » Wed Apr 07, 2021 6:48 pm
I want to see you get a tactrix open port and get a decent ECU tune done
Avenir
Postby Avenir » Wed Apr 07, 2021 9:21 pm
@Mars - Thanks mate!! Me too, It's been too long. Love to entertain as always.
@Viking - Thanks heaps! I think its never a truly educating experience without a few bumps on the road. At this present moment I just have to drive fairly sensibly as I still have no ASC. Which is a combination of Anti-lock braking system, Traction control function and Skid control function according to the manual lol.
@bumble - Yes all in due time, I have to get the exhaust fixed up and high flow cat etc. Then do it. I emailed Merlin last night but I haven't got a response back so I guess I'll just wait it out until he gets back to me.
TS Short Shifter
Postby bumblebee » Thu Apr 08, 2021 6:01 pm
well, while waiting for merlin, if your real serious about tuning, install a Wideband sensor, something along the lines of an AEM 30-4110 kit
awood
Postby awood » Fri Apr 09, 2021 7:26 pm
Great work mate , always good to tinker on the old girl and make her feel better on the road.
Postby bumblebee » Sat Apr 10, 2021 8:45 pm
Good on you for using Tinder bro glad it works for ya
Avenir
Postby Avenir » Mon Apr 12, 2021 10:06 am
@bumble - hahaha maybe... See how I go. Brother might have some around from his 4AGE corolla. Also don't think anyone said the word Tinder bumble?
@awood - Thanks mate! Exactly it, I would highly recommend putting some money into suspension hardware. It's well worth it and it makes your car really safe to drive too :)
TS Short Shifter
