Help with loud injectors.
LoafFace
Postby LoafFace » Mon Oct 29, 2018 8:06 pm
My injectors have been super noisy as of late. You can listen to it here https://youtu.be/lpJwtvX_-K4 hopefully some one can help me out.
2010 es lancer
To do list.
Coilovers.
Muffler.
EVO X bonnet.
Done.
Sub installed.
LED tailights.
Re: Help with loud injectors.
Postby lancerdarryl » Mon Oct 29, 2018 8:22 pm
Are you sure it's noisey injectors? Try unplugging one while it is running and see if the noise changes.
LoafFace
Postby LoafFace » Mon Oct 29, 2018 8:24 pm
Yes I have used a stethoscope and the clicks are being made by the injectors
2010 es lancer
To do list.
Coilovers.
Muffler.
EVO X bonnet.
Done.
Sub installed.
LED tailights.
Postby lancerdarryl » Tue Oct 30, 2018 4:40 pm
You have a few options 1 have the injectors removed cleaned and tested or 2 replace them with new ones.They usually get noisey if they have a restriction in them. It is unusual for them to be so noisey. I've never come across this in a Lancer before.How many K's has it done and has the in tank fuel filter ever been replaced?
Which ever way you go with the injectors I would be changing the fuel filter at the same time. Or 3 You could try a bottle of injector cleaner that you put in the fuel tank and use the car as you normally do it may work.
PS Buy your fuel from a high volume branded service station ie Shell BP or Caltex and don't use that rubbish with ethanol in it :)
