Page 2 of 2
Re: Mitsubishi Lancer sport sedan.
Posted: Fri Sep 14, 2018 8:16 pm
by ReeceCozaa
well, like they say sometimes no replacement for displacement, i'm sure any mods equally done the 4b12 will come in the winner due to its higher displacement, i mean my mate had an SX and when he drove in my GSR he saw the immediate difference; im not dissing but yeah pros and cons to all trims hey
Posted: Fri Sep 14, 2018 8:24 pm
by bumblebee
Have all the displacement you wish
If it's EFI and you don't do the basics your giving away power. Plain and simple
Posted: Fri Sep 14, 2018 9:35 pm
by ReeceCozaa
Hahah but if you do do the basics you’re all set ;)
Posted: Sat Sep 15, 2018 6:18 am
by bumblebee
Yes indeed and if you wish to take it further down the track with bigger pistons or cams or what ever your in front if the 8 ball,of the other guy who was too lazy to weapon the first place
Posted: Sat Sep 15, 2018 5:16 pm
by Lancer1993
Just add a turbo :)
Posted: Sat Sep 15, 2018 6:37 pm
by bumblebee
No thanks
There's more to life then turbos
Once you have an understanding you will see where I'm coming from
Posted: Sat Sep 15, 2018 11:22 pm
by ReeceCozaa
Turbo is easy, cheap power; and with the ralliArts/evo one big step up is the turbo upgrade which will then further take you to the next level, one which our NAs can’t ever do
Posted: Sun Sep 16, 2018 6:30 am
by bumblebee
Dunno where you guys came up with cheap power from.
I know for a fact you,can get bolt on kits for about 5 grand USA and that ain't cheap .by any stretch of the imagination.
There is cheap parts
Then is smarter ways to do things
And there is devises that make turbos look like Lego
Posted: Sun Sep 16, 2018 11:55 am
by rasit.aslim
Buy an iDRIVE throttle controller kit, easy to install and will give you that boost you're looking for without going all out :D
Lots of other similar devices out there too
More info on iDRIVE http://www.mccdandenong.com.au/index.ph ... t_id=19792
Posted: Sun Sep 16, 2018 3:27 pm
by ReeceCozaa
Hahah well look at it this way, if you were to do a straight bolt on kit and every single bit and bop to the NA then do a straight on turbo kit, the turbo kit would gain most power by far, just can’t beat forced induction on a 4cyl for power
Posted: Sun Sep 16, 2018 3:31 pm
by rasit.aslim
ReeceCozaa wrote:Hahah well look at it this way, if you were to do a straight bolt on kit and every single bit and bop to the NA then do a straight on turbo kit, the turbo kit would gain most power by far, just can’t beat forced induction on a 4cyl for power
iDRIVE or an alternative is the way to go bro!
That laggy throttle when you hit the gas disappears once the controller is turned on
Posted: Sun Sep 16, 2018 3:34 pm
by ReeceCozaa
Is iDRIVE a tuning application?
Posted: Sun Sep 16, 2018 8:24 pm
by rasit.aslim
Nah bro, sounds like it from the "i" though LOL.
Gets rid of the painfully slow revs
Check it out http://www.mccdandenong.com.au/index.ph ... t_id=19792
